TO-30 REAR LIFT SYSTEM
Al / Hocking Hi
10-03-2002 17:06:07
My neighbor just got a fire damaged TO-30 running again. The man he got it from said the problem with the lift has always been there. Problem is it lifts and lowers but when it does lift it goes all the way to the top. You then can lower it to where you want it. Anyone have a idea on whats going on and how to correct it? Any help is recieved is welcomed. Al
Al / Hocking Hills
10-04-2002 04:00:45
 Re: TO-30 REAR LIFT SYSTEM in reply to Al / Hocking Hills, 10-03-2002 17:06:07
Thank you for the replies!! This fits the problem and save my friend a lot of work. Al
Ray,IN
10-03-2002 21:08:50
It's working correctly. Search here for "zanethang" to link to the patent holder in the USA. This item will simulate the action of draft control and another item simulates live power for H.Ferguson TO 20/30 and certain Ford models.
Fergie26
10-03-2002 18:19:42
The TO-30 did not have position control like 8N Fords and that could be the problem. There are a couple of aftermarket add-ons available you can buy to get position control. We have the one designed by Stephen Gaunt in Australia. Someone is distributing it now in the the states.
Glenn Smith
10-07-2002 07:19:41
 Re: Re: TO-30 REAR LIFT SYSTEM in reply to Fergie26, 10-03-2002 18:19:42
You can check out the Gaunt Positioner at the following site.
http://users.netlink.com.au/~fergy/positioncontrol.htm
