Engine oil level
steve
10-03-2002 19:09:27
Can anyone tell me if the engine oil level on the dip stick should be in the middle of the full & low marks or at the full mark shop manual i have does not say. i have seen on other equipment like cat that it should be in the middle of the marks.The tractor is a 54 to-30.
Ray,IN
10-03-2002 20:31:05
 Re: engine oil level in reply to steve, 10-03-2002 19:09:27
The oil level max. is the top line. The level should not fall below the bottom line. Five and 1/2 qts. will refill the crankcase after draining the oil oil. The system holds 6 qts., but 1/2 qt remains in the system in passages, voids, low spots, etc. This is from the H.Ferguson owners manual.
steve
10-04-2002 12:34:51
 Re: Re: engine oil level in reply to Ray,IN, 10-03-2002 20:31:05
Ray thank you again for all your help.
