Engine swap
NCtim
10-11-2002 13:17:52
Hello,
I was wondering if anyone knows of an egine that will swap with a '49 TEA-2085 Standard engine. I'd like a bolt on conversion. Does the Continental engine bolt to the bellhousing in the same pattern?
Mine is shot, and cracked, and generally not worth rebuilding. I'd like an engine I can get parts for here in the USA. Every rebuild kit I find is in England or Sweden. Then I still have to weld the block.
Thanks.
Motor man(iac)
10-14-2002 10:23:21
 Re: engine swap in reply to NCtim, 10-11-2002 13:17:52
You can get all the rebuilding parts you want in the US - at Bareco in CA. subsidiary of a company from Australia. Check out their address:
www.bareco.com.au
Contact their office for a retailer nearby.
Or get a whole engine shipped over from Europe - not a big problem these days.
A totally rebuilt Standard 2085 can be obtained for the neat sum of just under $1k.
NCtim
10-14-2002 12:31:07
 Re: Re: engine swap in reply to Motor man(iac), 10-14-2002 10:23:21
Thanks for all the info, and to Rodney.
cdmn
10-14-2002 09:21:50
I've got one with that conversion, and I've seen at least one other. The Continental engine is between 1 and 1.5 inches shorter. So the front axle mount has to be doctored. (Maybe one from an 30 will work) Mine has the engine shimmed out from the bellhousing about 1/8 inch. Don't know why yet. It seems to work okay, but the Continental is pretty far gone, too. I'm doing research on a possible swap. Ford, Case, Allis, Massey, etc. Even some car engines, such as Jeep. Usually a problem with front mount, starter position, governor, etc. Some might not be structurally strong enough. Also flywheel face position relative to bellhousing flange after an adaptor is used.
Gary F
10-11-2002 18:30:31
You could try us up here in the Great White North Lots of these tractors, engines and parts are available here and with the value of your US $ you should do quite well.
Gary
