Don't steer me wrong
phil mi
10-12-2002 16:06:39
when turning the steering wheel to the right on my to20, the shaft seems to rise right out of the tube. is this an easy fix? how much skill does it take to fix it?
Steer or bull....
10-14-2002 10:13:23
 Re: don't steer me wrong in reply to phil mi, 10-12-2002 16:06:39
if it is the entire thing raising from the cast housing check the three rivets. if it is the wheel alone check top bearing - (a nice little job to get the wheel off, tho...)
phil mi
10-14-2002 14:50:13
 Re: Re: don't steer me wrong in reply to Steer or bull...., 10-14-2002 10:13:23
it is the wheel and the spindle it is attached to.
the wheel comes off easily (ithas a dorman key and slot). the shaft seems to screw itself out of the housing.
James, UK
10-15-2002 03:56:27
 Re: Re: Re: don't steer me wrong in reply to phil mi, 10-14-2002 14:50:13
Either side of the steering box close to the gear you'll see a nut about 0.75 inch/20mm across, in the centre of which is a screw. Loosen the nuts, and then screw in the adjuster screws to remove the slack. The problem you have sounds like the worm gear on the column is trying to 'climb' out of the steering box.
This is another good thing about the TE/TO series - almost everything is adjustable for wear - except the driver ;-)
Try it and see.
phil mi
10-17-2002 14:53:11
 Re: Re: Re: Re: don't steer me wrong in reply to James, UK, 10-15-2002 03:56:27
james,
tightened the two screws but the shaft is still climbing out of the housing. what else would you try.
Boogity - Ohio
10-15-2002 14:27:32
James - are you trying to tell us that you are n ot adjustable for wear?
James, UK
10-17-2002 00:07:17
 Re: Re: Re: Re: Re: don't steer me wrong in reply to Boogity - Ohio, 10-15-2002 14:27:32
All I can say is that some mornings it certainly feels that way. Maybe it's the home brew.
