Belt pulley to fit TO-30
Scott CT
10-14-2002 06:06:04
I have a 1951 TO 30 that I use for just about everything and I am looking for a right angle gear drive and belt pulley to attach to the PTO. I was just given a 3pt cordwood saw (dearborn) and would like to put it to use. Does anyone have a lead on one of these at a reasonable price?
scott
10-15-2002 18:51:34
 Re: Belt pulley to fit TO-30 in reply to Scott CT, 10-14-2002 06:06:04
Make sure you get the right size 1 1/8 or 1 3/8 shaft the little bracket bolts on the pulley for the saw ferguson or dearborn the same set up.
Bob Folkerts
10-15-2002 05:03:54
Just my 2 cents worth and something I recently learned. We have both types of setups (sorry not looking to sell) and they look the same when side by side. The only difference is that one has the built in top bracket to receive the top link coming from the buzz saw. As I understand it you need this bracket to accept the Dearborn type buzz saw. I have also been told that the Dearborn and the Ferguson saws are identical and were built by the same manufacturer. The bracket on the belt pulley is actually cast into the mounting base and points to the top when bolted on the tractor. I'm still learning about Fergusons (Dad is the expert) so it is possible that other brands of saws are not set up this way and can accept the standard "Ford Type" belt pulley.
Bob Folkerts
10-15-2002 06:49:34
 Re: Re: Belt pulley to fit TO-30 in reply to Bob Folkerts, 10-15-2002 05:03:54
Correction to my previous post. The bracket that I previously described is in fact on the back side of the Belt Pulley Setup and not on the front side as I previously said (It pays to go back and actually take another look) It is also a separate bracket that bolts onto the top two cover plate bolts and is not cast into the plate. This might mean that it is actually part of the saw and not part of the belt pulley. Hope I didn't steer anybody wrong with my previous post. Anyway I'm still a little red-faced about this and hope this information helps.
marlowe
10-14-2002 12:27:59
they got some 50.00 1-800-296-2045 it's in wi. but they ship
Willy-N
10-14-2002 06:53:14
Here is one on eBay that is for a TO 30 Ferguson. Mark H.
