Ferguson wrench
steve
10-15-2002 20:16:15
I have a ferguson wrench it has a ruler on one side (lenth ) and on the top is stamped with ferguson on one side and on the other side the # 180-108-m1.Does anyone have any info age,type or model?
Fergie Fan
10-19-2002 10:21:13
 Re: ferguson wrench in reply to steve, 10-15-2002 20:16:15
Sorry guys , maybe I am wrong , but we have used that wrench as a fuel gauge for 50 years , still got the wrench , tractor and my eye brows . Don't take my advice on this one-----2 cents worth---Bill
Fergie Fan
10-17-2002 14:16:47
Sorry guys , any ferguson wrench that I've ever seen was used as a fuel gauge , those marks are in Imperial gallons , one end is definitely 9/16 , but the big end is weel over 3/4 , more like 7/8 , it was designed to fit most bolts on a Fergie , including the wheeel nuts , makes a great hammer too----- Bill
Joe Ferguson
10-17-2002 17:49:24
 Re: Re: ferguson wrench in reply to Fergie Fan, 10-17-2002 14:16:47
Hi
The wrench ends are 9/16" and 1-1/16"
As per my TEA operators manual the ruler is to
measure plough depth.
Never measure gas level in the tank using a
metallic object...static electricity may cause
a spark and ignite gas vapors and then an unexpected explosion. Never use a metallic can
to carry gas for same reasons.
That's why now all gas carrying containers are made with plastics.
How about gas stations metallic nozzles ?
they are well grounded to earth to avoid static
electricity buildup.
"Good wrench" to all !
Joe Ferguson
DJH
10-16-2002 05:10:20
The spanner was supplied as standard with all Ferguson tractors of the era. The rule was for measuring the depth the plough was working to and was useful for setting the plough to work at the desired depth.
DJH
10-16-2002 05:10:18
paul
10-15-2002 20:56:06
The wrench is a cultivator wrench. The ruler side is for measuring the distance between the plow units. The wrench ends should be 9/16 and 3/4 inch
paul
10-15-2002 20:27:29
steve
10-15-2002 21:00:48
 Re: Re: ferguson wrench in reply to paul, 10-15-2002 20:27:29
Do you know what a wrench #to-17014 on it & a ruler?
steve
10-15-2002 20:54:12
paul thank you for the info.
