OK, having read the posts, I agree totally with the 'Leave the wires alone' approach. Concentrate on the carb. It is unlikely to be the air cleaner issue I first mentioned, as nothing there has changed. I'm intrigued by the posting reference the throttle valve spindle wear and air leaks there - not come across that one before. I posted a reply a while ago to someone who was having trouble with their tractor 'popping back' through the carb - mine did that because of a TINY air leak on the carb to inlet manifold gasket - like you I'd tried to re-use the gasket. It is possible that you have a sufficiently large air leak there to - as another poster said - give you an impossibly lean mixture. I would check that gasket and either replace it or use another cut from a cereal packet, plus a dollop of gasket sealer, and do the nuts up tight and true. If you put a steel ruler across the gasket face on the manifold and the top of the carb, are both faces flat - or are they bowed?? Bowed will cause you problems sealing, but it will look OK. If your carb is clean and that's all that's changed since it last ran, and your jets are set to the minimum recommended for setting up (3 turns open from fully closed on the main jet at the bottom) then the thing should run. Did you remove the brass main jet completely from within the carb body? If so, did you do it up tight when you replaced otherwise when you screwed the adjuster in, did the tapers lock, giving you no jet at all, and you're now only only winding a jammed jet assembly in and out? Are your plugs getting wet with fuel? If so then that's a whole new issue - and it isn't lean!! If they are dry, cheat and pour one teaspoon of fuel down each cylinder, replace the plugs, and see if she'll fire then. If they are wet, put them in a hot oven for 15 minutes (50 degrees C will do fine - but don't go hotter as it gets risky with the fuel already in the bores) and then replace them in the tractor. Using oven gloves is good. Then try to start. Good luck.
