Belt driven hydraulic pump TO-30
Brian - NB Cana
10-21-2002 15:11:02
I want to run a hydraulic pump for a Dearborn pipe loader on my TO-30, with a fanbelt instead of front mounting it. How do I attach a second belt to run the pump?? Double pulley ?? Help !!
ZANE
10-22-2002 07:06:40
 Re: belt driven hydraulic pump TO-30 in reply to Brian - NB Canada, 10-21-2002 15:11:02
See my post above this post. It covers the subject. I make and sell a live hydraulics kit that allows just what you describe plus you can still use the three point hitch with or without the PTO pump having to be turning.
It is called the ZANE LIVE THANG
TractorMike
10-22-2002 06:10:18
If you could find a way to attach the hydraulic pump to the tractor so it don't move, I would think you could get a bigger fan belt to go around all the pulleys, then you wouldn't need to double pulley the hydraulic pump, I don't think. Just a thought. TractorMike
