Re: TE-20
bob p
10-28-2002 14:50:25
looking for a few things for my te-20. I need a grill. And I need to know if I can just put a one wire 12 volt neg. grd. alternator and a 12 volt coil on it to make it work. I`m not having any luck finding a voltage regulator for it. Or will a voltage reg. off a tea-20 work on it? Any help would be appreciated. Thanks bob
Jim W
10-31-2002 10:48:28
 Re: re: TE-20 in reply to bob p, 10-28-2002 14:50:25
I believe a voltage reg from an early TEA is the same as both have Lucas electrics and TEAs below s/n 200,000 were 6 v. I know these are available as a colleague here just got one a couple of months ago.
Or, you could go the one-wire alternator route, but then you get to fabricate a mounting bracket. If you do switch to 12v, don't forget your light bulbs.
Regards,
Jim
