4 cyl standard diesel glow plugs
Charles W. Brid
12-04-1999 12:40:33
I have a TO35 with the Standard diesel engine that has a glow plug for each cylinder. I get the impression from reading that some of these tractors came with only an intake manifold heater. All my glow plugs are bad, Does anyone know if I can eliminate the 4 glow plugs and replace them with the manifold heater? There seems to be a plug in the manifold that would screw out to put the heater in.
Does anyone know of a good source for glow plugs if this will not work?
Thanks Charles W. Bridges
E-mail cbriddges@shelby.net
Joe Ferguson
12-06-1999 09:20:06
 Re: 4 cyl standard diesel glow plugs in reply to Charles W. Bridges, 12-04-1999 12:40:33
Hi Charles
My opinion: If you always park in a garage or near an electrical outlet the best is to add a
block heater in lower radiator hose.
If the tractor is left in the woods or outside in cold climate good glow plugs and good battery
will be better.
If you plan to modify to fuel heater in intake manifold if not originaly designed for this purpose modification should be hazardous...
You risk fire or explosion problems with insurance
and name it.
Hope thih will help
Joe Ferguson
Tim (UT)
12-05-1999 14:52:26
You can get the glow plugs right from MF for about $35 (US) each. I checked a while ago, but since I can get mine started with a little shot of ether, I haven't bothered with it yet (perhaps some day...)
Tim
Jack in NB
12-05-1999 04:14:48
Good morning, Charles -
I'm told the glow plugs are equivalent to a Champion CH-45. They used to be available from Vapormatic, at about $38 Cdn, but no longer.
They were used in the later 23C engines. The earlier engines used the intake heater or thermostart - about $34 Cdn. This thermostart has slightly larger thread diameter than those used in the Perkins, but the Perkins units will work in a pinch.
It requires replumbing to install a fuel source. The factory unit had a fuel reserve tank - about 1/8 cup in size, MF number 188 466 M91 or 827 305 M91, plumbed into the overflow line. It was mounted on the back right tank hold-down bolt.
It's critical to have the thermostart feed line connected to the bottom fitting, otherwise the thermostart is fried from fuel starvation.
Neither thermostart nor glow plugs really help in cold weather - a block heater is almost a must. We installed a 150 or 200 w heater (NAPA or UAP?) in the lower rad hose. Works wonders - you might think about trying it first.
Cheaper!
Hope this helps.
