Stuck Bolt
Andrew
11-15-2002 21:02:01
Gidday!
I have a Ferguson 5 ft finger mower. The bolt which holds the main supporting arm to the pulley box is seriousely stuck. I have bashed it heaps with a hammer, but it doesn't come out. I am also convinced that soaking in any kind of oil, etc will not wwork (I' ve tried). Does anyone have any ideas? I'm sure a bearing puller could do it, but there is nothing for it to grip.
Any help would be appreciated!
kevin
11-16-2002 04:53:11
 Re: Stuck Bolt in reply to Andrew, 11-15-2002 21:02:01
Heat required.Even a propane torch will do the job if you leave it long enough.Lots af antiseize when you put it back.
Good luck, Kev
