Ground Speeds
LB
06-08-1999 18:26:37
Can anyone tell me where to find approximate ground speeds of a TO-20, TO-30, and TO-35 in each gear.
Don Tieche
06-27-1999 18:06:32
 Re: Ground Speeds in reply to LB, 06-08-1999 18:26:37
According to my handy owners manual ground speeds for the TO-20 are:
@1500rpm and 10-28 rear tires
1st gear = 2.48 mph
2nd gear = 3.42 mph
3rd gear = 4.71 mph
4th gear = 9.84 mph
Reverse = 2.87 mph
@2000rpm and 10-28 rear tires
1st gear = 3.32 mph
2nd gear = 4.57 mph
3rd gear = 6.29 mph
4th gear = 13.13 mph
Reverse = 3.83 mph
@1500rpm and 11-28 rear tires
1st gear = 2.58 mph
2nd gear = 3.56 mph
3rd gear = 4.90 mph
4th gear = 10.24 mph
Reverse = 2.98 mph
@2000rpm and 11-28 rear tires
1st gear = 3.45 mph
2nd gear = 4.76 mph
3rd gear = 6.55 mph
4th gear = 13.66 mph
Reverse = 3.99 mph
Ratio through final drive
1st gear = 78.57 - 1 2nd gear = 57.04 - 1 3rd gear = 41.45 - 1 4th gear = 19.86 - 1 Reverse = 68.10 - 1
I hope this helps you.
Evan MacDonald
06-09-1999 12:12:19
That information can be found in the owners manual, usually in the transmission section, I have info on the TO 35 if you want it, but I'll have to dig it out. I know the top speed of a TO 35 is 13.86 mph with 11-28 tires, thats in high 3rd with about 2000 rpm(I don't remember all six ratings like I do that one).
Evan MacDonald
