Fouled plugs
Frank (VA)
12-26-2002 20:34:48
My plugs seem awfully sooty and a bit oily. I have been running the tractor under some stress lately. The tractor runs fine when warm, but rough cold and is a bit hard to start. Should I check the timing first or just lean it out a bit? My understanding is that these tractors are designed to run a little rich to keep the engine cooler under load.
I suppose I could leave it as is and just clean the plugs periodically. I am not much of a mechanic and could use any advice you'd offer.
thanks
Frank
phil (va)
12-27-2002 14:49:15
 Re: fouled plugs in reply to Frank (VA), 12-26-2002 20:34:48
For your stated situation, I like the Autolite 3116 plugs in a TO-30.
