HOOD LIMIT ON TO20
HANK
12-31-2002 04:32:22
PLEASE GIVE ME AN IDEA HOW TO LIMIT THE TRAVEL
OF THE HOOD ON MY TO20.
WHEN I RAISE THE HOOD TO AD GAS OR REPLACE BATTERY
HOOD GOES ALL THE WAY TO THE GROUND.
WAS THERE A CHAIN OR ROD TO LIMIT THE TRAVEL?
IF SO WHERE SHOULD IT BE ATTACHED?
Phil (VA)
12-31-2002 06:57:54
 Re: HOOD LIMIT ON TO20 in reply to HANK, 12-31-2002 04:32:22
Another option is to put a Ferguson bumper on your tractor. The hood will rest on it when you raise it. The Ford bumpers don't work, as the hood will not come all the way forward when you use that option.
paul in mphs
12-31-2002 06:06:40
there is supposed to be a 3/8 inch rod that runs across the bottom of the hood. It forms a lever on each side of the hood at the bolts that mount the hood to frame. In the center of hood under the hole for the hand crank is a notch about an inch wide with a rolled mouth. The 3/8 rod has a loop formed in it to catch this notch when the hood is raised. To lower the hood the levers on either side of hood is pulled back toward rear of tractor then hood can be l
