Ferguson TE-20 and its Marvel-Shebler carburetor
Carlson in Miss
01-01-2003 17:41:16
I need help!!! I have completely rebuilt the engine and carburetor on my TE-20. The over haul manual called for a closed position clearance for the float of 9/32 and an open position of 15/32.
Currently I have the open position set at 11/32 and the tractor still runs EXTREMELY RICH!!! In fact, I can close the low idle needle valve and the power needle valve and the tractor WILL STILL RUN!!!! The only time the tractor will run smooth is when I have shut the fuel off at the tank; and then, the engine will run smooth briefly until it has expended the fuel left in the bowl.
What causes the above to occur? And, what do I need to do to fix it?????
Norm in Ont.
01-01-2003 21:47:43
 Re: Ferguson TE-20 and its Marvel-Shebler carburetor in reply to Carlson in Missouri, 01-01-2003 17:41:16
Sounds like a float issue or/with dirt in needle.
Just dissassemble carb and clean it properly preferably overnight in carb cleaner solution. Then be very careful inspecting for small specks of dirt.
Good Luck
Norm
Carlson in Missouri
01-02-2003 01:34:10
 Re: Re: Ferguson TE-20 and its Marvel-Shebler carburetor in reply to Norm in Ont., 01-01-2003 21:47:43
Thank you, Norm. I appreciate your response.
Mike in Florida
01-05-2003 16:49:40
 Re: Re: Re: Ferguson TE-20 and its Marvel-Shebler carburetor in reply to Carlson in Missouri, 01-02-2003 01:34:10
Carlson,
I have had similar problems with my Fergie
and found 1)a pinhole in the float allowing
fuel to "sink" it, 2)lacquer build up on
the needle oriface.
Solder took care of the leak and a good
carb soak took care of the build up.
I guess the carb had not been deep cleaned
since the 50s....
Good luck.
Mike
Gordon
01-01-2003 19:58:29
Do you have aload ajusting screw,or a power jet.Something must be missing or the float has gas in it or the float valve is leaking.
Carlson in Missouri
01-02-2003 01:40:49
 Re: Re: Ferguson TE-20 and its Marvel-Shebler carburetor in reply to Gordon, 01-01-2003 19:58:29
Gordon,
Thank you for responding. Yes, the carburetor has a power jet. Oddly enough, I have replaced every replaceable part in this '52 Marvel Shebler carburetor. If it's possible, the carburetor body may just be wore out.
Duner Wi
01-02-2003 05:37:34
 Re: Re: Re: Ferguson TE-20 and its Marvel-Shebler carburetor in reply to Carlson in Missouri, 01-02-2003 01:40:49
Be certain the float does not rub the body of carb. This will prevent the float from shutting gas off as the bowl fills. It does not take much to cause problems.
