TO-20 blowing oil
Andrea Hodge
01-01-2003 19:09:12
Replaced old oil cap with new one, now it is blowing oil around distributor. What could be the problem?
Rusty
01-02-2003 15:39:34
 Re: TO-20 blowing oil in reply to Andrea Hodge, 01-01-2003 19:09:12
O-ring on distributor should prevent the oil leak.
Gordon
01-01-2003 19:48:01
If the breather is pluged and a loose cap ok tight cap air pressure has to go some place.
Mike in Florida
01-05-2003 17:05:05
 Re: Re: TO-20 blowing oil in reply to Gordon, 01-01-2003 19:48:01
Gordon is correct. There is a crankcase vent
pipe on the left side of the valve cover that
is to allow internal pressures out. (nowdays
apv-pcv valves re vent and are burned via
combustion.
Check the vent pipe for clogging OR the valve
guide holes if there is a chance oil burn/clogg-
ing may have occured.
Good luck.
Mike
