Pto to30 or 20
nick
12-09-1999 18:57:31
can,t get pto shaft out any help appreciated any one know what it is serial no. 70062 last number not sure of
mike
01-02-2000 15:22:30
 Re: pto to30 or 20 in reply to nick, 12-09-1999 18:57:31
nick to-20 has 120 cont. to-30 has 129 cont.engine its stamped on left side of engine block right above oil pan. later, mike.
ZANE
12-12-1999 06:20:55
If the tractor has been doing a lot of hard bush hogging you could have a twisted pto shaft and the only way that I know to get a twisted shaft out is to remove enough stuff to get to it with a cutting torch and cut it into in fron and behind the hydraulic pump. Grind off the end where you cut it at the pump and knock it out. Then get a new pto shaft.
