Front axle bushing wear
Mark
01-07-2003 19:41:03
I am in the process of replacing my front axle bushing on the TO-20 and noticed there is also wear in the piece that supports both ends of the center pin. Are these bushings that I can replace?
Rusty
01-09-2003 14:23:13
 Re: Front axle bushing wear in reply to Mark, 01-07-2003 19:41:03
Had the same situation on a Te20. Replaced the pin and bushing. Going to try it for a while and not worry about the other wear. The front end is much better than it was.
Duner wi
01-09-2003 11:57:10
I think the end pieces are part of the front support and can't be replaced seperately. If for some reason you decide to weld the center pin in solid better have the redius rods lined up correctly.
