>By your description I am not so sure your >generator is working. Where do you measure your >13.2 volts? After having read your answer I am not sure either. I measured the 13.2 on the battery. >The contacts of the regulator are supposed to >open when the output of the generator falls >below about 13 volts This COULD explain the whole situation. If the generator is producing just slightly more than 13 Volts this won't be enough to close the regulator contacts. When I force them to close they sometimes stay closed but most of the times open up again after a few seconds. Perhaps the generator is not "dead" but producing electricity just below the limit that the regulator requires. >Did you try opening and closing the contacts as >you describe at different engine speeds? If so, >did they close more easily at higher speeds? I closed them at the same engine speed each time. >Maybe the field winding has gone open. It's >supposed to be 6.2 ohms (assuming you have the >Lucas C39/2 generator). Can I measure this without opening the generator? >That 4 volts seems high to me, but only by >intuition. Perhaps I wasn't carful when measuring. I'll do an other test and read the instrument more carefully. >When you say the other terminals show no power - Hmmm, I wonder if I have mixed up the contacts on the generator. I might have measured on the small contact. There are no letters on the generator. The smaller one is located half an inch ór so higher than the bigger one. The higher should then be "F", right? >Here is a bit of text from the service manual: Interesting, thanks! >These cycles occur so rapidly that the points >vibrate at a high frequency and thus hold the >output at a constant predetermined maximum. The text above was what made me think the generator might be "almost okay". When I force it to start charging it does so. Sometimes it continous for a while and sometimes it stops charging almost instantly. When I force the contacts together the generator might be producing 13.19 volts or so... I see no vibrating of the contacts. They are either on or off. I wonder: If the generator is good enough to charge 13 volts but no more it can't be that bad can it? Would an inside cleaning help? Could this be caused by worn carbon brushes? If you have an auto electrical shop somewhere around, or even an older regular repair shop, they may have a rig to test it. If it were me at this point I would take the generator in and get it checked out. I suppose that is a good idea, but still I would like to see if there is a way to check the generator properly. Could I perhaps connect a flashlight battery to one termainal on the generator to get it started and then use a voltage meter on the other one to see what comes out. One thing more: Polarising: When I mounted the new regulator it said in the instruction that I sould connect D and F until >I saw a spark. I did this on the regulator. Should I have done it on the Generator instead or doesn't it matter? Kevin: A Chevy generator would probably be a good solution. There are two reasons why I won't do it that way. 1. In Sweden Chevys are quite rare and that goes for Chevy generators too, so if I'd replace the whole system I would probably use an alternator. (I have one from an old Plymouth Valiant). 2 Even if my Ferguson looks really sad at the moment I still want to keep it as close to what it looked like 50 years ago as possible. One day it Will get new paint and better tyres! Tomorrow I will quit work rather early. Hopefully I will be spending the evening with the tractor. Cheers Anders
