Bucket loader for TO-30
Mike
01-27-2003 04:09:35
Does anybody know if a front loader was available for the TO-30? If so what drives the hydraulics?
Patrick
02-06-2003 18:26:59
 Re: bucket loader for TO-30 in reply to Mike, 01-27-2003 04:09:35
Have a very nice davis loader from a T0-30. Dual action hydraulics. Will lift the front of the tractor off the ground. Bucket also has hydraulic control dual action. Very nice loader for sale cheap. Pump runs off the front pulley on the crankshaft. Have some pictures of the loader off the tractor, can get pictures of the loader on the tractor. About a half hour job to remove or install loader. Located in central Missouri. Thanks
Russ
02-18-2003 16:07:40
 Re: Re: bucket loader for TO-30 in reply to Patrick, 02-06-2003 18:26:59
Would this loader also fit a TO-20? If so I'd be interested as well (also in Missouri)
Thanks
Russ
jeff
02-05-2003 16:23:44
i have a lord loader on my 51 to30 was told it is a good one
Barry Reid Stirling, Ontario
01-28-2003 05:54:58
Hi Mike
I happen to own such a loader. Its an original Ferguson loader complete with serial number LVO20 16865. E-mai me and I will send you some pictures on how it works, Kinda simple , Its for sale as well
Phil (VA)
01-27-2003 06:56:11
The loaders that fit the 9N, 2N, or 8N Fords will fit the TO-30. The loader front pump can be driven off the front pulley on the tractor, same as on the Fords. I have a Wagner WM3 on a TO-30 that came off an 8N. It bolted right up, using the same bracket for the front axle that was used on the Ford. The stinger for the pump and pulley was close to the correct length and with a few washers to shim it works fine. You may need an adaptor for the pulley, available from dealers. This style loader bolts to the rear axle using the fender bolts, so it must be the exact length, unless you plan to fabricate brackets, etc. Consequently, loaders of this style that fit the NAA or TO-35 (longer tractors) will not easily fit the TO-30, but the loaders that fit the 8N, etc., fit very well as they apparently are the same length axle to axle as the TO-30. Having said all that, with this style loader, the TO-30 has the problem of not being able to raise the hood once the loader is installed. You will need cutouts for the fuel and radiator, etc., or else cut the hood and install clamps. The latter is especially needed for battery maintenance. Hope that helps.
