Ferguson TO-35 tranny
ROGER
12-13-1999 12:36:04
I just bought a 1959 TO-35 and discovered when I got it home that the Hi/Lo range shifter junps out of Hi after only a few seconds of tractor movement. It doesn't matter whether it's forward or reverse and does it in all gears. If I forcefully hold the lever in Hi poosition it'll stay but I can feel it wanting to jump out of my grip which it does eventually. Can anyone tell me specifically what's wrong? Much obliged. Roger
mike
12-26-1999 15:49:56
 Re: Ferguson TO-35 tranny in reply to ROGER , 12-13-1999 12:36:04
evan,your hi-low planitary gears are probably worn,or shift fork is bent,you have to split tractor right behind the dash panel-in front of seat its on rear of trans. case . good luck! mike.
Evan MacDonald
12-14-1999 11:46:08
Sounds like the ball on the bottom of the shifter is worn, keeping the planetary gearset from engaging completly. The shifter can be removed by pulling up the boot, and driving out the pin that holds it in. It can be built up with weld, but, you must be careful it doesn't end up too big.
Evan MacDonald
James McKinney
03-13-2000 18:57:05
 Re: Re: Ferguson TO-35 tranny in reply to Evan MacDonald, 12-14-1999 11:46:08
Please Help! I have a 56 Ferguson TO-35 that has recently locked up, transmission wise. The Tractor runs great, but only in high or low first gear. It refuses to shift to second, third, or reverse.
The shifter seems to be stuck solidly in first. Any advice would be greatly appreciated! Thanks, James
