Gear shift lever
Albert, IN
01-31-2003 12:53:06
I have a 1950 TO 20. The gear shift lever will shift the transmission into any gear, and all the gears work fine. The problem is that when the tractor is in motion (in any gear)and I release the gear shift lever, the lever and the transmission will return to neutral.
rod
02-01-2003 03:45:31
 Re: gear shift lever in reply to Albert, IN, 01-31-2003 12:53:06
If you take the shifter out and have a look at the spring on the end of it that could be the problem I have had them jump out of 2nd gear but never all the gears other than that it could only be badly worn transmission.
regards
rod
