1949 TE20 Wheels
Stan (WA)
02-11-2003 15:53:18
I recently purchased a TE20 that has good bones and needs a lot of TLC. I am currently looking for a supplier for new wheels 4.50x19 as my tractor's wheels are badly dented in the rims. Can they be replaced with 4.50x16 wheels as a last resort?
I am also looking for a supplier for a new grill and hood as they are badly dented and extremely rusty.
Thans, Stan
Harvey at YT
02-13-2003 07:12:55
 Re: 1949 TE20 Wheels in reply to Stan (WA), 02-11-2003 15:53:18
Stan, we have a ton of parts here at our store at YT for the TE20, you might want to check our prices. I'll put a link below. If the link doesn't work for you, just click on the "Tractor Parts" link on your left (under Marketplace), then select Massey, then select the "TE20" link (not MH50). You'll see the parts availability is quite good.
Thanks, Harvey (link below)
Duner Wi
02-12-2003 15:31:34
the fergusons I am familar with have a 4.00X19 tire , The rim is closer to 3.00 X19. The outer rim is avaliable from the after market. You have to use your centers. The 8N Ford has the 4.00X19 rim also .
Damon
02-12-2003 14:21:32
Stan,
are you located in WA, Australia? If so Bare-co and Vapormatic sells a 4.50 x 16 inch rim for the fergie. From what I understand the fergie came out with the choice of the 16 or 19 inch rims. The only seem to make the 16 inch rims new now. I don't know how much the rims are.
