3-Point weight Limit
TE20
Jeff- Oh
02-17-2003 16:25:02
What is the general weight limit on the hydrolics for a TE20? I am looking at a disc and the weight is about 760 lbs. Would this be too taxing on the system if carried to and from the field?
My hydrolic system doesn't seem to fave a problem lifting my 5 foot bush hog off the ground approx weight 500 lb.
Are there any ruls of thumb for other implements. Obviously I do not want to break any
Dennis in MA
02-17-2003 17:14:37
 Re: 3-Point weight Limit - TE20 in reply to Jeff- Oh, 02-17-2003 16:25:02
I've got 1300 pounds on mine - a backhoe. If it weren't for the weight of front end loader, the front wheels would come off the ground, but the 3 pt still lifts the load.
Jeff
02-18-2003 05:23:26
 Re: Re: 3-Point weight Limit - TE20 in reply to Dennis in MA, 02-17-2003 17:14:37
Thanks for the reply but are you running a T_-20. Just want to double check.
Dennis Foye
02-18-2003 11:01:13
 Re: Re: Re: 3-Point weight Limit - TE20 in reply to Jeff, 02-18-2003 05:23:26
To30 - same machine except for the engine
