Manifold to exhaust clamp
Axel
02-18-2003 05:06:42
Hi,
The manifold to exhaust clamp in my TO 20 is so rusty that it does not hold th exhaust in place anymore. This causes fumes and noise. Can I get a new one somewhere? Is there a chance to get drawings for making a new one? My old one is a 2 piece cast iron clamp.
Any suggestions?
Boogity - Ohio
02-18-2003 19:08:41
 Re: Manifold to exhaust clamp in reply to Axel, 02-18-2003 05:06:42
Here is something that I have tried with pretty good success. If the connection end of your cast iron exhaust manifold is pitted and will not allow a good seal against the flaired end of the exhaust pipe cut a section of an aluminum beer or soft drink can and wrap it around the connection just under the cast iron clamp. The diameter of a drink can is perfect for this use and it allows a small amount of overlap. I usually cut a 1/2" wide strip of can material and wrap it around the connection joint then install the clamp. It's not perfect but it sure helps. I think I have three layers of aluminum on mine now and it's sealed very well.
Axel
02-19-2003 04:39:01
 Re: Re: Manifold to exhaust clamp in reply to Boogity - Ohio, 02-18-2003 19:08:41
Thanks for the help.
I tried the tractor parts at the left of the screen, but could not find it. I will keep looking...
Jeff - Oh
02-18-2003 05:29:27
The clamps are readily available and run about $3.50. Check your parts source or the parts link at the left.
Ray,IN
02-18-2003 18:33:09
 Re: Re: Manifold to exhaust clamp in reply to Jeff - Oh, 02-18-2003 05:29:27
Most all farm stores carry them, as well as MF and Ford dealers.
