If it's only tight at one part of the rotation, take the pair of rotors out, and check all the tooth profiles visually for any nicks or burrs, especially on the tips of the rotors, as it sounds like you may have a slight ding on one tooth. This is especially easy to happen if the rotors are steel. If you mesh the two rotors and roll the outer rotor round the inner rotor in your fingers, you will be able to identify more easily which tooth pair is causing the problem. If there is a ding, try polishing it out with a carborundum stone - or a finishing file (if the rotor is metal and not a sintered material which will be too hard to file) - or take it back and ask for a replacement, before you invalidate any warranty. Also check the inside of the pump body for any foreign material, as this can cause the same symptom. Clean it thoroughly. The risk of 'letting it all bed in' is that the pump may sieze while running, with potentially disastrous results. The final assembly must be free running, with no contamination, and no tight spots. You are replacing both rotors aren't you? They run as a matched pair, so don't try to replace only the one that was cracked - you must replace the inner and outer pair together. Natural gear mesh should be as smooth as silk, with no tight spots, no grittiness, and no noise during the complete rotation. Hope this helps.
