Engine temp.
George
02-25-2003 14:26:19
Can anyone out there tell me what the normal engine temp. should be for a TO30 with a four cycl. gas engine? Did not have a temp. gauge on it since I have had it some twenty years or more. Installed a temp. gauge and thermostat and it operates at 170 on the gauge. Is this correct? Thanks George
Ray,IN
02-25-2003 18:54:25
 Re: Engine temp. in reply to George, 02-25-2003 14:26:19
Thermostats are available for 160* and 180*; sounds like you're right in the middle. Did you also install a new radiator cap? I think it's 4# pressure.
George
02-26-2003 06:20:20
 Re: Re: Engine temp. in reply to Ray,IN, 02-25-2003 18:54:25
Ray - appreicate your reply. I did put a 160 in it but did not replace the radiator cap. I have also replaced the radiator. I'll give it a try! Thanks so much for your time. George
