Access plate on TO-30 differential
Mike
03-06-2003 18:38:23
When I drained the fluid out of my TO-30 I noticed a lot of sludge in the differential access plate. There is a fluid gallery on the right side leading to the 3point hitch and when I feel around inside the differential there seems to be something dealing with that gallery. Are there precautions that I need to be aware of prior to removing the cover to remove the sludge?
Thanks
marlowe
03-06-2003 18:51:44
 Re: Access plate on TO-30 differential in reply to Mike, 03-06-2003 18:38:23
what access plate? on the side or bottom? the only plate on the bottom is the hyd. pump plate! DO YOU HAVE A SERVICE MANUAL???if not get one!and do not remove cover untill you disconnect the 3 point control fork or you will brake the valve bone in half
Ray,IN
03-08-2003 19:33:01
 Re: Re: Access plate on TO-30 differential in reply to marlowe , 03-06-2003 18:51:44
I second that Marlowe. Mike, have you removed all three drain plugs to completely drain each area: diff/hyds/trans? Each area will retain nearly 2 qts. of fluid if not drained individually, and it will be water, sludge.
