Fixin a 35
clyde in oh
04-02-2003 11:11:13
Can someone give me a ballpark on the cost of: overhaul with new pistons, sleeves, rings, valves reseated, new crank (not turned or rebuilt), 2 stage clutch, (pressure plate ok) rebuild hydraulic pump. Will have to have someone do the work, I'm unable. Live in eastern Ohio.
george
04-03-2003 20:36:28
 Re: Fixin a 35 in reply to clyde in oh, 04-02-2003 11:11:13
My uncle just bought a new crank for TO35 made here, not out of the US, over $400. He said it was fair price. I think every rebuild is different in that most don't replace what is ok. To Joe in Houston, I'd bet you never had to figure out a two stage clutch. No problem at a good Fergie shop. I don't know parts price, but in Ill. you would have at least $600. in labor at a GOOD honest shop.
Joe in Houston
04-03-2003 10:34:02
Clyde, Remind me to stay out of you area if I need a rebuild. I am in Texas and a friend of mine just had an 8N 4 cyl done (Top to Bottom) for about $800.00.
I guess it depends on how much gouging the shop is doing but I would look at small out of the way places. Usually get better work done and get it a lot cheaper.
Thanks Joe
Phil (VA)
04-03-2003 13:22:57
 Re: Re: Fixin a 35 in reply to Joe in Houston, 04-03-2003 10:34:02
Don't forget he needs a new crank and a hydraulic pump rebuild and a new two-stage clutch in addition to the normal engine rebuild. And parts for a 35, since they are more rare, are probably more expensive than for an 8N.
Phil (VA)
04-02-2003 13:07:32
I would guess close to two grand from reputable shop, with new crank, pump rebuild and two stage clutch.
clyde
04-02-2003 20:35:36
 Re: Re: Fixin a 35 in reply to Phil (VA), 04-02-2003 13:07:32
Phil, thank you sir
