12 V Conversion
Dave in MO
04-02-2003 12:26:07
I'm converting my TO-20 to 12V. I think I have everything I need except for an adapter for mounting the new alternator. Is there anyone who sells the adapter W/O buying everything else?
Dave in Mo
04-04-2003 15:05:31
 Re: Re: 12 V Conversion in reply to John, IN, 04-03-2003 18:15:34
John, Can you give me the length of each piece on the mounting bracket, top, bottom and outside and also the size stock. I don't have the equip. to make one. I' going to have a machine shop make one for me, from the pic. Thanks Again, Dave
Dave in MO
04-03-2003 20:57:55
Thanks for the pic John. I didn't know what it looked like. At least I know what I'm looking for now. You'd think as many people converting, someone would have them on the market commercially.
Larry in Missouri
04-03-2003 08:58:43
 Re: 12 V Conversion in reply to Dave in MO, 04-02-2003 12:26:07
Dave,
Don't know where you are in Missouri, but I have a TO30 with a 12V conversion and you can come by and look at it if you're anywhere near Washington, Missouri, about 45 miles west of St. Louis. Otherwise, I can take pictures...
Larry in Missouri
James, UK
04-03-2003 01:02:31
Dave, do you mean mounting bracket when you say adaptor?
If so, there was someone who posted on this board recently who had a design available - so it may be worth looking back through the archives.
I've never seen a commercially available bracket, most people make their own up.
Rusty
04-02-2003 14:59:02
The belt on the tracor is wider than the alternator. Did you find a pulley?
Herb/pa
04-03-2003 04:59:33
 Re: Re: 12 V Conversion in reply to Rusty, 04-02-2003 14:59:02
Converted my 30 to GM alternator. I used old belt with thinner pulley on alt. You must make sure the three pulleys line up or you'll throw off the belt. It won't charge at start up til you get over approx 1200 rpm. It starts in the winter now!
Dave in Mo
04-02-2003 18:22:51
Rusty, I have not found a pully yet.
Rusty
04-02-2003 19:27:31
 Re: Re: Re: 12 V Conversion in reply to Dave in Mo, 04-02-2003 18:22:51
The owner of a small tractor auto parts store in this area can get them. They are an expensive high quality machined pulley. $16 I will ask him where he gets them.
Jim W.
04-03-2003 13:13:55
 Re: Re: Re: Re: 12 V Conversion in reply to Rusty, 04-02-2003 19:27:31
I am doing this conversion too and just ordered a 2.5" diameter pulley for a 3/4" belt from a local alternator shop, which should be in tomorrow or Monday. It is $22 Cdn, but he says it is not very high quality. There is also some special nut involved; I will report back once they have arrived.
Jim W.
PS He also says the belt will have a tough time going around that tight a bend so I should convert to the newer cogged type.
Dave in MO
04-03-2003 18:28:46
 Re: Re: Re: Re: Re: 12 V Conversion in reply to Jim W., 04-03-2003 13:13:55
Larry in Mo: I live 150 miles south of Stl.
James UK: Yes, Mounting Bracket. I'll ck archives.
Herb: Don't know if orig belt (wide) will work in the narrow pulley of GM Alt., or will need new pulley.
Jim: Let me know on pulley.
Rusty: No Pulley yet. Value Bilt said they don't carry the mounting bracket. Let me know on pulley.
Dave
Jim W.
04-04-2003 19:51:33
 Re: Re: Re: Re: Re: Re: 12 V Conversion in reply to Dave in MO, 04-03-2003 18:28:46
I picked up the pulley today; it is quite good quality after all. The guy said when he ordered them in the past, they weren't as good as this. I am actually quite impressed; it appears to be machined rather than cast. It was $20.28 Cdn. The pulley is thicker than usual (of course) which leaves just a few threads sticking out on the shaft. To deal with this there is a recess in the pulley, so that the special nut has more threads to grab on to. Special nut = $6.28 I think. About $30 Cdn total after taxes.
Very happy with the result, but it will be some time before this alternator is put to use so can't tell you how it performs electrically - I'm sure it will be great though.
Now I have to find the right belt.
Jim W.
Dave in MO
04-05-2003 12:46:02
 Re: Re: Re: Re: Re: Re: Re: 12 V Conversion in reply to Jim W., 04-04-2003 19:51:33
Sounds great Jim. Where did you order the pulley from? I'm going to have to start bushhogging pretty soon, prob. within 2 weeks, so I need to get my tractor going soon. Dave
Jim W.
04-06-2003 17:29:55
 Re: Re: Re: Re: Re: Re: Re: Re: 12 V Conversion in reply to Dave in MO, 04-05-2003 12:46:02
I got it from a place in Ottawa, Ontario, called Ascot Alternators. I don't have their number here but if you search on Google you can find it.
Don't know if the border crossing guys nick you they way they do us with goods coming this direction; if so, it might be cheaper for you to get it in the States.
If you do call these Ascot guys, mention that I just got one and they'll remember what this is about - it's only about a 4-man shop and I was there just on Friday.
Jim W.
Jim W
04-08-2003 14:20:45
 Re: Re: Re: Re: Re: Re: Re: Re: Re: 12 V Conversion in reply to Jim W., 04-06-2003 17:29:55
Came across the receipt and here are the part numbers:
pulley: 43570
special nut: 44100
Jim W
