Draft control
mike
04-08-2003 18:27:20
On the TO 35 deluxe what position should the draft control lever be for mowing, snow plowing, above ground operation? The manual isn't clear or I'm a little thick.
Big Dean
04-10-2003 17:03:11
 Re: draft control in reply to mike, 04-08-2003 18:27:20
The Draft lever should be in the down position when you are using the Position control lever to raise a lower the three point on the TO35
Mike
04-10-2003 20:34:29
 Re: Re: draft control in reply to Big Dean , 04-10-2003 17:03:11
Dean, if I'm just using the tractor for mowin & pullin is it OK to leave draft control in down position all the time?
