Gasket sealer
Andrew
04-09-2003 23:43:09
Hi!
Is it ok to use silicone gasket sealer on the carby- manifold gasket, on a Fergy TEA?
James, UK
04-10-2003 00:06:39
 Re: Gasket sealer in reply to Andrew, 04-09-2003 23:43:09
So you've found at least one air leak then?
Yes, you can use silicone type gasket sealer - but don't use too much.
I've used two home-made gaskets to prevent the problem - two sheets of 0.015 inch thick gasket paper should do the job. Plus a smear of instant gasket on all faces.
Andrew
04-10-2003 12:25:17
 Re: Re: Gasket sealer in reply to James, UK, 04-10-2003 00:06:39
Well, I haven't actually found a leak, but I've been taking off the carby for various things, and keeping the old gasket, so its a likely spot. That or the manifold gasket- when I removed the fuel tank a while back, some of the manifold studs were only finger tight!
