CRACKED BLOCKS
Ken in Memphis,
04-19-2003 10:36:26
Has anyone ever use KW block sealer? If you have tell me if it did ok. Thanks Ken
John Herlinger
05-01-2003 06:27:05
 Re: CRACKED BLOCKS in reply to Ken in Memphis,Tn, 04-19-2003 10:36:26
I had a to-20 with cracks between each of the cylinders in the block. I took it to a crankshaft repair shop in Cincinnati and they drilled and tapped at right angles to the cracks all the way thru the block to hold the cracks together tight. Then I used the KW block sealer and it worked perfectly. No leaks anywhere. Be sure to follow directions carefully.
