Trailer Hitch or Draw Bar
Barry reid Stir
04-29-2003 09:35:38
Afternoon Everyone
I asked this question a very long time ago, but need some more info. I own a 1952 TEA-20 Ferguson. I spent the last few nights building a trailer to haul my wood up with. I tried it last night for the 1st time. Worked great but the only problem is that I dont have a Draw Bar/Trailer Hitch on this tractor. I hooked the trailer up by putting a draw bolt down thru the bar thats hooked onto the 3 point hitch. This way of hauling a trailer would be ok if I were hauling on a flat level surface, Im not and every time I go over a rock or an uneven piece of ground the 3-point hitchs swazes back and forth throwing my wood onto the ground. I NEED A DRAW BAR. Where would I get one,and if I can put one on my tractor does it fit under the back where the bolts are already. It looks like all I have to do is get one take of the bolts that are there already and Im good to go, any help would be great. Thanks Barry
kevin
04-29-2003 16:49:28
 Re: Trailer Hitch or Draw Bar in reply to Barry reid Stirling Ontraio, 04-29-2003 09:35:38
Barry, you could either get a swinging drawbar kit new or from a wrecker, or use the the staybars with a 9 or 11 hole bar. The staybars have recently become available at Princess Auto. They can also be had at any New Holland store.
David
04-29-2003 15:38:12
Drawbar plate fits right onto the four bolts underneath and darwbar attaches to teh plate with two pins. There is also a type that bolts underneath and fixes to the hinged pin below the top link attachment too. For the 9 hole drawbar you are supposed to use two stays that fix to the hinged pin. These stop it going up and down and also from side to side.
Wayne Smith
04-30-2003 15:04:35
 Re: Re: Trailer Hitch or Draw Bar in reply to David, 04-29-2003 15:38:12
I purchased a Swinging Drawbar kit from Stevens Ag Parts, Coushatta, Louisiana ( 1-800-333-9143) for my 1951 TO-30. It works very well and the drawbar can be easily removed for attaching 3-point implements if needed. The part # for the kit is: SDA6 and the price for Drawbar, Hanger and Clevis Assembly was approximately $105.00 plus shipping. It was a bolt-on kit and fit exactly the way it was supposed to.
Hope this helps.
Barry Reid
05-01-2003 10:51:23
 Re: Re: Re: Trailer Hitch or Draw Bar in reply to Wayne Smith, 04-30-2003 15:04:35
Hi Wayne
Thanks a lot for this info. Im in Canada so I will look here 1st and if Im stuck I will call them
Barry
