Camshaft bearing bores
Milton Kirkland
05-03-2003 11:01:06
The camshaft bearing bores in the block of my Z129 engine are oversized.The front bore is .0135 O/S; centerbore is .007 O/S and the rear bore is .0025 O/S.According to the specs in the manual,my block is junk.Is this true,or can it be repaired.Thanks,Milton K.
Rusty
05-05-2003 14:20:26
 Re: camshaft bearing bores in reply to Milton Kirkland, 05-03-2003 11:01:06
That can be fixed. If the bores being oversized is your only problem you got no problem.
Dan S (NY)
05-03-2003 12:10:26
I'm pretty sure you can have a machine shop line bore the camshaft bearings and put in inserts. If someone has had this done, hopefully they will comment. Don't junk that block!
Dan
