1950 TEA-20 GEAR SHIFT
DOUG
05-03-2003 18:12:05
I bought the tractor today after driving it for a while it will not shift out of first gear. The shift lever will move but dosen't disingage from first. The tractor starts by using the shift lever i can still start the tractor. Any ideas will be help full
John
05-04-2003 04:39:43
 Re: 1950 TEA-20 GEAR SHIFT in reply to DOUG, 05-03-2003 18:12:05
Sounds as though the lever has come out of the gear selectors, probably worn a little. Remove the oil filler plug on the left of the gear lever and you should be able to get the lever back in the selector again with a little persuasion. Try to get the lever in the position of first gear and you should be able to see where it goes in the selector.
DOUG
05-04-2003 06:03:08
 Re: Re: 1950 TEA-20 GEAR SHIFT in reply to John, 05-04-2003 04:39:43
By nine this morning had gear shift back in position and on the move again. I took the gear shifter and cover off to see where to place it. Thank you for the great information and a quick response.
