Ferguson TE-20 regulator
Don
05-11-2003 16:55:13
I need a regulator for a 1948 TE-20 with Lucas system - Continental engine. I believe the regulator needs to be matched to the generator (or for those across the pond - dynamo). I bought a delco regulator for a T0-20 but the wiring is different and in reading the manual I believe this regulator is not matched correctly for the Lucas generator. Appreciate feedback on this.
tractornut
05-13-2003 08:51:51
 Re: Ferguson TE-20 regulator in reply to Don, 05-11-2003 16:55:13
could you please let me know if you find one? I have been looking for a long time, and only one I have found is in England and expensive. Thanks
Al in BC
05-11-2003 19:00:34
Don. If this is of any help you require a Lucas Regulator # RF 97 for 6 volt. or equivalent. I am looking to see if a outlet styill exist. If you are in Canada MF still carry I believe
Al.
Jim W
05-11-2003 19:29:52
 Re: Re: Ferguson TE-20 regulator in reply to Al in BC, 05-11-2003 19:00:34
Yes, a guy I work with here in Eastern Canada got a new one just recently (or really it came with the tractor, uninstalled).
Jim
Don
05-13-2003 16:27:04
 Re: Re: Re: Ferguson TE-20 regulator in reply to Jim W, 05-11-2003 19:29:52
I located one today. I called my local Massey Ferguson dealer who used the "spider" system to search inventories of MF dealers. They located one at a dealership in Ohio. I called them and bought it. The Ohio dealership said it was the last one they had and my local dealer said this was the only one that showed up on the spider system. You may still want to check with a Massey dealer. There were more TE's sold in Canada - maybe Canadian dealers would have one. I'm not sure if the "spider" system checks the Canada dealers. The one I bought was not cheap - it will cost me close to $100 with freight vs a delco unit for the TO's at $35. Good luck.
