FE35 Clutch
Larry Counts
05-18-2003 04:10:29
I discovered a problem when I shifted my FE35 into gear with the clutch in. The tractor moved forward. I stood on the clutch & brake pedal but it still crept along. The pto lever engages freely into all 3 positions with the engine running and no use of the clutch. Previously the pto would grind a little if I didn't press really hard on the clutch, It had been running perfectly until I moved it a few feet with the emergency brake on. It has the 2 stage clutch & Standard diesel. Could this be an adjustmet fix, or a tractor splitter.
Thanks,
Larry
john(UK)
05-18-2003 13:10:32
 Re: FE35 Clutch in reply to Larry Counts, 05-18-2003 04:10:29
Check the clearance of the clutch pedal first, there should be 1/2" freeplay in it. If the adjustmet is correct and the tractor still creeps and the gears grind as you engage them it does mean the engine out I am afraid. Then maybe you will be able to adjust the clutch fingers if the rest of the clutch is ok when its checked.
