DASH TO AIR CLEANER HOSE.... ARE THEY THE SAME?
MIKE IN FLA.
05-22-2003 09:53:25
HI, I;M LOOKING FOR THE TOP INLET HOSE FOR THE AIR CLEANER, I FOUND ONE ON BARE-CO'S SITE, BUT ITS FOR TEA-20, WILL IT WORK ON TO-30, THANKS,MIKE.
Paul in AZ
05-24-2003 06:01:00
 Re: DASH TO AIR CLEANER HOSE.... ARE THEY THE SAM in reply to MIKE IN FLA., 05-22-2003 09:53:25
Bareco has both the 1/8" lip used on the TO-20/30 and TO/FE/MF 35 and the 1/4" lip version used on the TEA. The 1/4" lip version will also work on the TO/FE/MF 35. They use the same part # for both. When ordering, tell them which one you want.
Paul Nelson
Jim W
05-22-2003 15:30:11
I got a couple of BareCo part# B5083 (although I didn't order them through BareCo), to put on my TEAs.
They almost fit but not quite, so maybe they will fit on the TO30 just right.
The difference is the "flange" at the grille end. It's a bit too thick, making it hard to screw the cover back on over the grille.
I put one on and just kind of squashed it but wasn't happy with that. For the second I think I will try to trim down the thickness.
Your mileage may vary,
Jim W.
MIKE IN FLA.
05-22-2003 17:19:42
 Re: Re: DASH TO AIR CLEANER HOSE.... ARE THEY THE in reply to Jim W, 05-22-2003 15:30:11
THANKS FELLA'S, I;LL ORDER ME ONE,IF IT TAKES A LITTLE HELP TO FIT I;LL MAKE IT WORK. THANKS MIKE
john(UK)
05-22-2003 11:29:51
Yes, pretty sure they are the same, only the engine was different.(not strictly true but near enough)
