Brush chopper disassembly
Terry Mi.
05-22-2003 16:44:47
I hit a dirt pile last weekend wich stopped the tractor. Anyway it broke a weld that held on a 1/4"x8"x24" steel plate the gearbox was mounted to. Also bent the plate, now I need to take apart to straighten the plate so the blades mow level again. Problem I can't get the large pan that the blades are mounted to. I have removed the nut, but can't seem to budge the pan. Is this pressed onto the shaft? I need to get to it to get to the nut under the gearbox. Or am I going at it wrong? Appreciate any advice. Terry
