TE-20 brakes
Andy
05-26-2003 12:18:36
I'd like some info on how the TE20 brakes work.
There is the main brake lever on the right side of the tractor and two independent pedals on either side connected directly to the back brake shaft meant to apply independent braking to either side. How does this work?
On my tractor the main brake lever when applied, via the linking rod, rotates the brake shaft top toward the rear which raises the independent brake pedals making them in operative. In other words the two independent pedals act opposite to that of the main pedal. This is odd. Perhaps my brakes are set up wrong.
Can anyone explain how this works or perhaps have a close up picture of the linkage to the brake shaft?
Thanks
Andy
john(UK)
05-26-2003 16:59:42
 Re: TE-20 brakes in reply to Andy, 05-26-2003 12:18:36
The independant pedals will lift up when u press the main pedal but if you need to brake one wheel you can also lift UP the independant pedal too and that will brake the wheel. Occasionally due to lack of grease, the pedal linkage will sieze up and the independant brakes linkage will not work, usually though when that happens it will try to bend the brake rods when you apply either independant brake.
Look here for more info:-
http://www.holland-brand.co.uk/infofiles/S42592.asp
David (Scotland)
05-27-2003 03:22:19
 Re: Re: TE-20 brakes in reply to john(UK), 05-26-2003 16:59:42
As John says independant pedals will work when lifted or pushed down. They just operate a cam within the brake drum that expands the shoes whatever way it moves. An old guy I know tells of the time he put a TE20 through a hedge when without thinking he lifted one of the pedals that had stuck down.
