Govenor assembly
Milton Kirkland
05-26-2003 19:26:17
I am rebuilding a Z129 in a TO-30.Do I need to use the shim that comes with the govenor assembly kit? There are no instructions in the kit.Thanks,Milton K.
Duner Wi
05-28-2003 12:00:26
 Re: Govenor assembly in reply to Milton Kirkland, 05-26-2003 19:26:17
Early TO 20s had a flyweight govenor. When replacing the flyweight govenor with the Novi Ball govenor a shim was recommended in the I T manual. Shim was about 1/16 inch thick. This is just a guess but your kit may be for both types of govenors and when replacing a flyweight style govenor you need the shim. This is only a guess.
