FERGUSON TE 20 SN: 82443
ROY BOATMAN
01-02-2000 09:06:24
THE COIL WIRE LEADING FROM THE COIL TO THE DISTRIBUTOR IS OF A KIND (SCREWS INTO THE DISTRIBUTOR) THAT i CAN NOT FIND A REPLACEMENT FOR IT. aCCORDING TO THE LOCAL MASSEY FERGUSON DEALER "THEY DO NOT MAKE THIS PART OR HAVE IT IN STOCK FOR ORDERING" i'M NEW TO THE I'M NEW TO THE TRACTOR AND HAVE ONLY HAD IT FOR A COUPLE OF MONTHS WHEN IT WOULD NO LONGER START. aNY HELP WOULD BE APPRECIATED. THANKS IN ADVANCE!!
Dusty Dave
01-02-2000 10:34:26
 Re: FERGUSON TE 20 SN: 82443 in reply to ROY BOATMAN, 01-02-2000 09:06:24
Try car parts shops that deal with old British cars. This screw-in design is common to many old British cars. It may take a lot of searching. I THINK you can get a later distributor cap that takes the common push-in wires, and a non-ballast coil that takes the push-ins is a very common car part.
You might also be able to find an auto electrician who can take the old ends of the wire and attach them to a new wire. Good luck.
tea dave
01-02-2000 10:47:45
 Re: Re: FERGUSON TE 20 SN: 82443 in reply to Dusty Dave, 01-02-2000 10:34:26
i bought a set of wires of that type from my m-f dealer less than 1 year ago. old stock? if you can't find them where you are post a follow up and i will inquire at my dealer. (southwestern ontario,canada) best of luck.
Dusty Dave
01-02-2000 17:50:03
 Re: Re: Re: FERGUSON TE 20 SN: 82443 in reply to tea dave, 01-02-2000 10:47:45
Whereabouts are you in Ontario, Dave? I'm in the Niagara Peninsula, near Jordan. Can you let me know who your dealer is? I'd like to deal with someone who knows these old tractors. I've found one mob in our area so far, the Case dealer "Red-Trac". Cheers.
tea dave
01-02-2000 19:06:24
 Re: Re: Re: Re: FERGUSON TE 20 SN: 82443 in reply to Dusty Dave, 01-02-2000 17:50:03
i am near essex dealers name is carlton mc guire sales and service 2 locations 519-723-4485 is best in my opinion other location is 519-687-2028 also we have a tractor wrecking yard but don't have # handy i can get if wanted i would e-mail you direct but i don't have your address
Clarence Carhill
01-04-2000 19:11:59
 Re: Re: Re: Re: Re: FERGUSON TE 20 SN: 82443 in reply to tea dave, 01-02-2000 19:06:24
I bought a new TE20 in 1948 and I still have the tractor. I buy the old style plug wire with the copper wire at a good parts store. I take the old wire and unsolder the little flat washer, then strip the new wire back about a 1/4" stick it through the little hole, bend it over, and solder it back on again. Simple little chore.
I purchased a new Lucas cap, points and condenser several years ago from Central Tractor in Des Moines, Iowa. I can get their 800 number for you if you want it.
