Rear axles on TO-20
Albert-IN
05-30-2003 13:07:53
The rear axle seals were leaking on both sides of my 51'TO-20. I removed the rear axles and took them to a MF dealer. They replaced the seals, bearings, studs, etc. ($421.00 ouch!) Now I have run into dufficulty reinstalling the axles. I can install either one of the axles, and it goes in fine. But when I try to install the second axle, it seems to bump into the end of the first axle, and I still have about a quarter of an inch to go befor the axle retainer can butt up against the housing assembly. I used the same shims that were on there before. Am I forgetting to do something, or could the new parts installed by MF be different from the original ones? Any suggestions would be greatly appreciated.
Ray,IN
05-30-2003 19:09:50
 Re: rear axles on TO-20 in reply to Albert-IN, 05-30-2003 13:07:53
Assuming all else is fine, adding shims to obtain the proper axle spacing, per the repair manual, is the correct procedure.
