Ferguson TEA Engine specs.
Norman Jelfs
06-13-1999 21:06:40
I need engine specs. for a Fergusson TEA
with a Standard Motor from England.
Bob
06-21-1999 03:46:08
 Re: Ferguson TEA Engine specs. in reply to Norman Jelfs, 06-13-1999 21:06:40
Norman, I'm not sure what specs. you want but I will give you some out of my
original book that came with my TEA. If you want further info e-mail me.
Bore 85mm, Stroke 92mm, 2088cc (127.4 cu in) Comp Ratio 6:1, Firing order 1
3 4 2, Belt HP 28.4 at 2000 rpm, Valve clearance inlet 0.010in outlet
0.012in, Distributer points gap 0.015in Spark plug 0.030-0.032in TEA's
came out in 1947-1956 and the engine was the same one used in the English
Standard Vanguard car. Hope this helps. Bob.
