Gear shifter boot
steve
06-06-2003 14:35:34
My 54 to-30 has a metal shift boot,is there a rubber boot that goes over this or is the meta 1 the only one?
Al in BC
06-06-2003 16:44:28
 Re: gear shifter boot in reply to steve, 06-06-2003 14:35:34
Good day Steve.
My TEA 20-85 did not have a rubber boot. I looked in the parts book to see if it had one origanlly. It showed it as part # 8 which is the metal shroud that covers the housing and is attached to the shaft by a pin.
I was still getting water in transmission case. I stopped this by putting a piece of shrink fit on the shift shaft over the joint on the cover and shaft and that stopped the water getting into the transmission.Hope that helps or has answered your question.
Al.
steve
06-06-2003 17:15:37
 Re: Re: gear shifter boot in reply to Al in BC, 06-06-2003 16:44:28
Thank you for your help al my to-30 has a metal 1 with a pin 2. thanks steve
