Wide TO-20
bartfish
06-08-2003 18:26:40
I have a 1951 TO-20 and I was wondering what the normal width between the tires was. Mine measures 6 ft. across from outsides of the rear wheels. After seeing quite a few of them around I realize mine is about a foot wider than any I've seen. I see know way to narrow the back wheels. Did Ferguson make wider versions of the TO-20?
rod
06-09-2003 19:22:53
 Re: Wide TO-20 in reply to bartfish, 06-08-2003 18:26:40
the operators manual shows 8 positions for the rear wheels if you send me your email I will send a scan of them my email is rodswinamer@ns.sympatico.ca
regards
rod
Bartfish
06-10-2003 18:50:26
 Re: Re: Wide TO-20 in reply to rod, 06-09-2003 19:22:53
Thanks, but I ordered an operator's manual, just waiting for it to come. I was just more curious than anything. Thanks alot though. I do Love this site!!!!! !!!!
Terry G
06-08-2003 20:25:51
The width between tires are adjustable to 8 different widths measured from center of tire to center of tire. The settings are 48, 52, 56, 60, 64, 68, 72, and 76 inches. Front wheels are adjusted by assembling the three-section front axle in various lengths. Rear wheels can be adjusted by turning the dish of the wheel 180 degrees when mounting it on the hub. The rim can be unbolted and turned 180 degrees on the wheel. And the wheel can be bolted to either side of the bolt holes on the rim. Using all the possible combinations of the above you can get 8 different widths. You will have to switch the wheels from one side to the other on some combinations to keep the tread direction right. This is kind of hard to see without a diagram. If someone don't post one I will try to scan one and send to you. Ain't old tractors fun.
Terry G
