Piston sleeve
Milton Kirkland
06-10-2003 17:52:07
While installing the piston in #1 cylinder,I noticed a small crack at the very bottom of the sleeve.The crack is about.040 long and is nowhere near the piston rings or the "o" rings.Is this going to cause a problem?What should I do?Thanks,Milton
James, UK
06-11-2003 07:05:25
 Re: Piston sleeve in reply to Milton Kirkland, 06-10-2003 17:52:07
Humph, misread your original posting - you said sleeve, not piston - so yes, stress relieve the crack with a small hole at the end(s) to stop it spreading, provided the piston isn't going to go over the hole during its travels up and down the bore.
Too quick off the keyboard, there, wasn't I. Oh well.
Jim W
06-11-2003 06:19:18
Do you mean the crack is in the piston skirt, or the cylinder?
If it's in the cylinder sleeve, you can drill a small hole at the end of the crack so it won't continue.
Jim W.
Duner Wi
06-11-2003 05:56:08
Cracks tend to grow. If your crack is .040 or 1mm I might just grind or file the crack out. Removing .040 at the bottom of sleeve should not bother anything. I would be concerned how the crack got there in the first place. Defective workmanship from the mfg. If that is the case I might replace the sleeve.
James, UK
06-11-2003 01:00:48
Any crack is a bad thing - how much do you want to do the job again, and how much damage do you want to do to the bore if the piston goes?
If it were me, I'd replace the piston now while the engine is in bits.
