WHere can I find a top governor spring for TO20
murphy
06-16-2003 07:22:09
I broke the top spring that goes from the arm to the waterneck housing and need either a new one or advise on what type and strength spring I can susbsitute, many thanx
Mike H
06-25-2003 12:27:38
 Re: WHere can I find a top governor spring for TO2 in reply to murphy, 06-16-2003 07:22:09
I had the same problem and I didnt have the old spring to look at. The shop manual says the spring length is 4 inches but can be shortened to 3 3/4 inches if the throttle slips. I used a 3 3/4 inch piece of screen door spring. Seems to work fine. btw..Did you find a factory spring?
Paul in AZ
06-16-2003 18:47:38
Contact Mac Tractor Parts at 1-800-992-4742. They have a supply of good used Ferguson parts.
Paul
James, UK
06-16-2003 08:20:16
Simplest solution is probably a trip to the nearest breaker's yard, but otherwise, hang what is left of your spring on a stout nail or hook, and measure the distance the spring moves (its extension in mm) when you hang a known weight on it.
This will give you a known value, which will be a constant, and can be checked against other springs (ie in catalogues).
You will also need to know its length (or what it was before it broke), and how many full turns/coils there were on it before it broke.
Wire diameter, and end fittings will also be needed.
You could then approach a spring manufacturer or spring stockist to see if they had a close match for what you are looking for.
From memory, it was a strongish spring, so you could try the simple(?) approach and destroy an old door closing spring or similar just to see if it would work . . . .
Just some thoughts.
