V-belts for Ferguson sickle bar
'52 8N (MD)
07-02-2003 04:48:27
Even though I have one good belt (out of two)and the original owners manual, I still cannot find the belt that fits my Ferguson (Detroit Harvester) agricultural mower (sickle bar). The model is 6A-EO-B20 and the manual is for the "A" series (A-EO-B20). THe local M-F dealers can't even match up the number on the one M-F belt I already have (668117M1). Any help surely appreciated. wc
James, UK
07-02-2003 06:21:25
 Re: v-belts for Ferguson sickle bar in reply to '52 8N (MD), 07-02-2003 04:48:27
If you can measure the outside diameter of the two pulleys, and the distance between the pulley centres, then any drive belt supply shop should be able to supply belts of the correct size - they use some sneaky math formula to calculate belt length, then they just use a look up table.
The other (farming style) alternative, is to run a length of string round the bottom of the vee for a full loop of the two pulleys, and then mark off the start and end point with a pen where the string overlaps. Do not stretch the string, but don't leave it loose, either.
That gives your belt length, and you can then take that to a belt supplier . . . . and start looking.
Hope this helps. First option is easier, but only works for two pulley systems - not three or serpentine systems.
Don't forget to leave the belt adjustment in the 'loose' position when you do this, as you need to allow for belt tightening with age/wear.
'52 8N (MD)
07-03-2003 09:30:31
 Re: Re: v-belts for Ferguson sickle bar in reply to James, UK, 07-02-2003 06:21:25
Thanks for your input. I found JDV-belts.com and the fella there shared the elusive formula with me:
Sum of Outer Diameters of pulleys times 1.57 plus 2 times median distance between centers of pulleys. For my 6A-EO-B20 mower this is:
[8"+ 5.5" X 1.57] + [2 X 10.25] = 41.695"
The tricky part is knowing that the DayCo/Goodyear belt numbers need to be adjusted upward by a half of an inch to compensate for the pitch of the belt. So say the DayCo number is 24408 (First two digits are in 32nds of an inch 24/32" belt width by 40.8" length, the last three digits). To get to the compensated effective length that equals the output from the formula above you add a 1/2". So since I needed a belt with a nominal length of 41.695" the DayCo 24410 is a good match - 24/32" = 3/4" width by 41"+.5"= 41.5".
Again, thanks for putting me on the right track. Without your post I wouldn't have known to ask for the formula. wc
James, UK
07-07-2003 01:18:47
 Re: Re: Re: v-belts for Ferguson sickle bar in reply to '52 8N (MD), 07-03-2003 09:30:31
Glad I could help - and thanks for posting the formula - I've now added it to my list of useful 'stuff' in the back of my book.
JA
